bp71k5
3/4 ton status
So I picked out one of those van tilt columns that are supposed to work ok in a first gen. After I disassembled it and regreased the bearings and cleaned it up, I got around to removing the column shifter and filling the holes since I swapped the auto tranny out for a manual.
The aluminum housing that the shift lever attaches can't be welded up (at least by me) so I ground off the parts that stick out and filled the holes with glass-reinforced JB-Weld. It worked very well.
The thinner steel portion that the shift indicator screws onto would have been to fragile for JB Weld so I made steel plugs and welded them in very carefully. Try not to poke fun at my weld beads as I'm definately not a pro.
