nad
So as some of you know, I just had a carbureted 350 put in my 87 Jimmy, and I'm having some problems with the carb because it needs a rebuild, but the truck is still drivable. But after I drive it for awhile, like 30 minutes to an hour, you can smell something like it's burning and the truck starts running like crap. If I leave it sit in park, it will stay running, but idle rough. If I put it in gear, it will run really rough, and eventually die.
In order to start the truck, I have to pretty much floor the gas, and once it's started I have to keep pumping the gas to keep it from dying. The guy that helped me put the motor in seems to think it's possibly vapor lock or a bad fuel pump. Any other suggestions, or does one of these sound about right?
