I hated the 2 "Veryjunk" carbs I had on my 81 G-10 van and '79 C-10 truck with 250 camel humper sixes with the integral cylinder head..
They didn't flood,but were always too lean on the primary barrel and too rich on the secondary,they were terrible when cold until fully warmed up,and they loved to have a "bog" when you opened the throttle ,and felt "flat" when you needed power..they are one of GM's worst carbs to work on (as I'm sure you know now!) and few people can get them to run well..
Ryoken is probably right about the float needle,I know I put mine on wrong more than once!..I even bought a brass float,thinking ethanol gas was making the foam ones sink!..
I got so fed up with mine that I made a crude carb adapter out of 3/4" plywood and mounted a Edelbrock 500 cfm 4 bbl on the original manifold on my pickup,and actually drove the truck to see if it would run OK before having a "real" one made of aluminum...
I found it ran better with just the primary barrels working,so I just left the little linkage off that opened the secondaries--if I tried booting the 4 bbl in it would lay an egg and bog down--too much air & fuel for a six I guess....had a local machine shop copy my wooden adapter and made one of 1" thick aluminum...hardest part of making it work was rigging up brackets for the throttle and detent cable ,but it wasnt a big deal,I was able to use a Mr. Gasket universal one for the detent and a stock one modified for the throttle..
I actually liked driving the truck after the carb swap,it was like a whole different engine compared to the vari-jet carb..more torque and pep by far...unfortunately the engine lost the top ring lands on the #6 piston at 117K,,probably due to preignition from the vari-jet running too lean..it had about 97K on it when I swapped the carb..
My van always pinged under a load too,I decided to swap a 307 in it before the six expired,but it was still running OK at 160K when I swapped the V8 into it..
The engine never spark knocked with the Edelbrock,and I was able to get 16 mpg with it too...
