vent line question for doubler users
sweetk30
Back to play nice .
in the back of your brain
did you connect bot the 203 and 205 together for 1 line up top or did you keep them separate ?
i have 1/4" barb fitting nipples and using 3/8" o.d. plastic air brake line hose d.o.t stuff . i have roll of it figure why not .
just need to know if good or bad to tee them to 1 line . will be running same fluid in both box's also .
I tied my 203 & 205 together and ran the single vent tube to a high spot on the firewall. I don't have a ton of wheeling time on it but it's been on the street for a few hundred miles with no issues.
o.k. got ya now. the way you worded it it was like you said i was mixing all in 1 for every thing .
Oh no, one per. Far enough North that inbreeding and intermingling is frowned upon
My doubler shares the vent, everything else has its own homerun to the firewall...
