Vent tube breathers
cybrfire
1 ton status
Iowa
Made from 2011 aluminum. 7/8" body diameter, with a servicable construction. Spring retention cap prevents vibrations from loosening the cap, yet keeps the breather easily servicable, with no tools needed. Inside is a 30 micron sintered bronze filter. The body has a built in 3/8" barb fitting. Mounting is achieved with a rubber damper and snap ring retainer. Designed to be used with a 1/8' thick mounting surface.
Be careful not to cross thread the cap!!!
Be sure to look at our mounting flanges for the easy installation! http://diy4x.com/cart/index.php?route=product/product&path=40&product_id=168
$25.00
http://diy4x.com/cart/index.php?route=product/product&path=40&product_id=167
A double set installed in my blazer on the fan shroud. These two will be used for the rear axle and fuel tank.
last day for the vent tube breather giveaway!
Putting a note in here so I can find these quickly. With trans and transfer currently out of Krusty, seems like a good time to put those vents up out of harms way.
You'll like them. Nice addition.
