Vent Window Hardware
LNielson
SE Idaho
Anyone happen to know what the upper bolt is in the vent window hardware. The bolt that installs just below the vent window and fastens through to the outer door skin? I'm missing one and don't want to pull my other door apart to find out unless I have to.
@kennyw ?
are you talking about the part that keeps the top of the vent glass connected to the vent frame? Pretty sure I used a two piece rivet to reconnect mine if that’s what you’re talking about.
Can you ID the part on this diagram? I think you are talking about 60/61? I have them in a bin. The screw is just a sheetmetal screw.
Yeah #5, I know it is a flange headed bolt of some sort, but I don’t know the size/length.
If I had a selection of bolts in front of me I could pick it out but I have no idea what size or thread pitch.
I know it's a small bolt, fine thread and either 3/8" or 7/16" head
It’s a #10-16 tpi screw, like a metal roofing fastener. Should be easy to find one that will work. Thanks again
