Venting axles
BrianDamage
Alabama
Trying to finish up my 1-ton conversion, been so long since I scrapped my original axles, I can't remember how the stock axles were vented...I mean, I know there was the tubing coming from the axle and attached up high to keep it out of the muck, but my 1-ton axles only have a hole in the top... is there some sort of fitting that goes in there to attach the tubing to? surely its not just mashed down in the hole :confused:
Stock there was a nipple fitting that was presses into that hole. Unless you can find a good one to press back in there (and if the hole is wobbled out egg shaped). Or you can get yourself a screw in air fitting that will fit the hole. Which will mean that you'll have to pull the cover to be able to run a tap down that hole to cut some threads.
hope I can find one....I see what you're talking about though..the 14bolt actually has one on there, I just didn't notice it at first
