FWBlack
Newbie
Hi;
I recently purchased a 88 K5. Someone has replaced the headlights with an aftermarket halogen kit w/relays. Never having a dual headlight vehicle before, I'm not sure how to adjust them, nor am I 100% sure the aftermarket kit was installed correctly. I can see better with low beams than hi! I tried eyeballing adjusting them last night and got it a little better.
The low beams are on the bottom and are dual element. When high beams are on, all 4 lights are on. The low beams change which element is in use between low and hi. Does this seem correct?
I've seen instructions on marking a wall or garage door with headlight height, park vehicle 24 feet out and aim low beams 2" below and 2" to right. But could not find instructions on how to do this with 4 headlight setup.
Any help will be greatly appreciated.
Thanks!
Thanks!
