Kain
3/4 ton status
so i installed this thing ,started by making a template for the mounting holes out of cardboard and drilling the holes . mounted the pressure regulator on the passenger side behind the spare tire with nut serts.
Mounted the relay on the driver side inner fender close to secondary battery.
Iput the rocker switch in the dash where the rear window switch used to be
