COKE
Registered Member
I removed my 3.07 ratio 10 bolts rear axle and put a 12 bolts with a new set of 4.11 gear and a Eaton posiperformance unit.
After solving my brakes issues,i have gone out for the gears break in procedure.
I have noticed a horrible vibration from the rear,mostly under acceleration and at high speed when the OD was engaged and i pressed the pedal.
I have backed home and i have lost the wheels nuts and torque them again.
Also i have removed the pinion yoke four bolts and i have turned the diveshaft positon 180º.The shaft is the one wich came from the factory.I put a 10 bolts yoke on the 12 bolts to fit it.
Now it goes better,but still vibes a bit.
The yoke side u joint was replaced few miles ago,so it is almost new .The T Case side one doesn,t seem to be bad.
The new gear set manufacturer specs (Motive gear)are 2.750" pinon to ring centerline distance and 0.08" backlash
I finished setting up with 2.756" and 0.10" Backlash.Could these small differences cause the vibes or would i need any kind of balancing?
The wheels are 33s the same that i had before the gears swap.
. In fact ,the suggested BL for my front axle gear set was 0.010".
i need to mount the original set up for passing the Vehicle Technical Inspection twice a year.
