BasscattinBlazer
Newbie
Hello to all, This is my very first post on this forum and glad to have a place where can talk to fellow Blazer owners. I have an 85 K5 w 6" lift that has a vibration at low speeds. I just recently had the rear pinion bearing and the u-joints replaced but the vibration still exists. I had the truck up on jacks to see if the u joints were binding but they seem fine. I was hearing a roar at the rear of the tranfser case. I pulled the tailshaft cover expecting to find a bad bearing but all is tight. It did look like a funny wear pattern was on the race within the tail shaftcover . The slip yoke is not smooth where it will contact the seal or the race.
Could a worn race cause a vibration at this point of the driveline and could it be a combination of race and slip yoke? Also, if the yoke is an issue, does it make sense to just put in a new cardan style driveshaft or just fix the old one? I have heard differing opinions about a 6" lift not needing the cardan style
