chevyguy82
Registered Member
this is my first post. i've got an 82 blazer with 6" bds suspension/all spring with 35" bfg mt's. i have a bad vibration when i hit the gas hard from a dead stop and also sometimes going down the road. i have replaced the u-joints and still have the problem. i also have a problem with the bottom leafs moving out. u bolts are tight. i have broken 2 u-joints now. it came with shims already on the spring packs. i lowered the transfer case. angle isn't that bad. do i have to lengthen my driveshaft? it has a new 700r4 connected to a 208. since the lift the driveshaft has come out about 4 inches. i flex it out but fear the shaft might come out. does anyone else run this setup? thanks for the help guys.
