ChuckMoney
Registered Member
Title says it. I set up a 14bff with 4.56 axles and I'm getting a lot of decel and low speed vibrations. The backlash was right in the money hole at .005 with a great pattern, did not require any shims.
Currently the truck doesn't have any rear shocks, the ones from ORD were too short. By the way, this is the largest 4" lift I've ever seen in my life, seriously, the 35's look small. Top height is over a hair over 7ft with 315/75/16. Shackle flip rear, 3" springs front, 1" body lift with new body mounts.
It almost feels like a bad U-joint, but only during decel under 15-20mph. Pinion angle looks decent, driveshaft looks fairly straight to the pinion, I would say about a 20* angle.
I'll shoot up some pics tomorrow of pinion angle and other pics ect.
Any ideas? I know this post is written as a 5th grader would, but 16hrs working on this from a completely stock truck and now about 5 drinks its expected.
Thanks ahead of time.
. Or the ujoint like you mentioned. On a side note my front shocks were too short and my rears were too long from ORD. They work good enough for the driving I'm doing for now though
