I have been gearing up for moab for about 2 months with my 84 K-10 lwb. It is fairly stock with a 2.5" superlift, 33" truxs, trutrac/detroit in the 10 bolts (I know), mild 350/700/208. I called offroad design to get a swaybar disconnect and ask what else I needed to best avoid problems. So now I have a steering box brace, disconnects, and greasable shackles, with longer shocks and axles in the mail as we speak(great people by the way). Still need to install the shackles. So Stephen tells me to go try my truck on the most steep hill I could find and see if it stalled. Well saturday I went up the hill I have in my pasture. The hill is grass covered and about 42-45 deg depending on the part. With minimal spininng it when right up and it even has a holley ta. While pulling the hill is made a growl/vibration that sounded like it was from the front driveshaft. It has never made this noise before but I don't go up steep stuff much here. Again last night I was hauling a load of rocks for the wife up a steeper hill and the noise again. Could it be I am getting some spring wind up and it is changing the u-joint angle? All the u-joint feel great. I just don't want to blow up anying and have to fix it in the middle of BFE if I don't have too. Sorry this is long but I wanted you to have all the specs.
