alright, is there a special part number for the u-joint's??? i have an 85 Jimmy with a np208 and a 10 bolt rear
i pulled the d-shaft and looked at the joints to make sure they gave me the right ones at the parts store and apparently the PO modified the shaft or i'm just dealing with a bunch of guys that don't know what they're doing.
so on the d-shaft the u-joint has the external clips to hold the cap in and on the slip yoke it has the internal c-clips holding the caps in. then on the other end of the shaft (the one that goes to the pinion) it has the internal clips
i'm getting confused, i think the PO did something to the driveshaft. anyway, is this what you guys have on ya'lls or is it just me???
