Vin decode assistance.
ripperoo187
ft rucker
So I just put a deposit down on this:
http://fairbanks.craigslist.org/cto/4527687500.html
Talked him down to 3200, test drove it. No play in the steering wheel, manual hubs. Shifts great, brakes work, 4wd works, and has more get up and go than I was expecting. Just a little surface rust and engine leaks a bit of oil underneath. Not perfect cosmetically (no dents though) but yeah pretty stoked! Since my K5 is in storage right now I need a rig to haul stuff.
Well I did a search on the VIN to decode what factory options the truck has could anyone break it down for me? 1GCHV33J5MF302168 1991 Chevy K3500. Thanks fellas. I am hoping for a Detroit in the back and not a Gov bomb, the seller said that there is something back there. I could not feel anything when I accelerated on the road.
Here's some pics in case the seller decides to take the ad down.
Description:
"1991 Chevy k3500 crew cab 4x4. 6.2L diesel newly rebuilt 4L80E trans, like new tires. Injection pump rebuilt and turned up by advance diesel, new radiator and ps pump. Beautiful old Chevy. I've had it for 10 yrs and taken great care of it. Hate to let it go but I must. $3500 obo."
Doh!
Well I did a better search and found most of the info is accurate. I guess the only way to know for sure what the gear ratio/presence of a locker is to pull off the diff covers. I swear I won't thrash this truck :)
Detroit was only in m-series trucks .
our reg stuff got gov-loc. but in a 14ff there a lot better than smaller axle units. I run them my self with no problems.
Thanks.
Yeah its original owner was a ski lodge. I gunned it when I test drove it and I know what both a gov lock and a Detroit feel like, felt nothing really. I am hoping it is open with 4:56's. Guy said it has a locker, we shall see. Do you know what type of transfer case came in these trucks?
1 year only 4l80-e with 205 gear drive case.
and 90-91 205 were electric speedo . . along with other vehicles having the electric speedo also .
Thanks again man.
Awesome! I have been wanting a 205. I did feel 4th gear when I drove it. So I am sure I have a 4l80.:woot:
you want pan shape #7 to be a 4l80-e
#3 = th-350
#4 = th-400
#6 = 700r4
#7 = 4l80-e
and pic of back side of 205 case . note 3 bolt cover in middle . and cast iron case body .
heres a break down of the vin for ya
1SA = PACKAGE-OPTION 01 (1SA) 47I = INTERIOR TRIM,DARK RED (47I) 47W = TRIM COMBINATION,VINYL,DARK RED (47W) 6S7 = SEAT CLOTH TRIM,WITH VINYL DOOR TRIM SEAT TRIM(6S7) 72U = EXTERIOR COLOR,PRIMARY (72U) 8N1 = COLD CLIMATE PACKAGE,DIESEL,USED WITH ARCTIC GRADE FUEL DIESEL COLD CLIMATE PKG(8N1) A01 = WINDOW,TINTED GLASS(ALL WINDOWS) TINTED GLS(A01) A52 = SEAT,FRONT BENCH,3-PASSENGER FRT BENCH ST(A52) AS3 = SEAT,REAR UTILITY R/SEAT(AS3) B3J = DIESEL EQUIPMENT PACKAGE DSL EQUIPMENT PKG(B3J) BY1 = ORNAMENTATION,EXTERIOR,BODY EMBLEM BODY EMB(BY1) C6W = GVW RATING(9200 LBS) 9200 LB GVWR(C6W) CMD = PLANT CODE FLINT, MI, GM T&B FLINT, MI PLANT CODE(CMD) D44 = MIRROR,OUTSIDE,BELOW EYELINE(PAINTED) O/S PAINTED MIR(D44) E63 = BODY EQUIPMENT,FLEETSIDE PICKUP BOX FLEETSIDE PUBX(E63) FLT G80 = AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) GQ1 = AXLE,REAR,STANDARD RATIO(MERCHANDISING OPTION) STANDARD RATIO R/AXL(GQ1) GT5 = AXLE,REAR,4.10 RATIO 4.10R(GT5) JB8 = BRAKE SYSTEM,HYDRAULIC POWER DISC,DRUM HYD PWR DISC/DRUM BRK(JB8) K60 = GENERATOR,100 AMPERE 100 AMP(K60) LL4 = ENGINE,6.2L(6.2J),DIESEL V8 6.2J(LL4) MT1 = TRANSMISSION,AUTO,4-SPD,THM-R2(4L80-E) 4-SPD AUTO TRANS(MT1) MX0 = TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) AUTO TRANS PROVISIONS(MX0) NA5 = EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) NY7 = SHIELD,TRANSFER CASE TRFER CASE SHLD(NY7) Q1F R04 = WHEELS,SINGLE REAR SINGLE RR WHL(R04) R8T U73 = ANTENNA,FIXED FIXED ANT(U73) UN9 = RADIO SUPPRESSION EQUIPMENT RDO SUPPR(UN9) UP7 = RADIO,PROVISIONS FOR MONAURAL INSTRUMENTATION RDO PROVISIONS(UP7) UT5 = RADIO,AM,ETR,INCLUDES CLOCK AM CLK RDO(UT5) V43 = BUMPER,REAR STEP(PAINTED) PAINTED REARSTEP BUMPER(V43) V73 = VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) VQ2 VQ6 VXS X88 = CONVERSION CHEVROLET CHEVROLET(X88) XYN = TIRE FRONT LT235/85R16/E BL R/PE ST TL HWY (9590803) TIRE(XYN) YD3 = AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3) YD6 = SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6) YK6 YYN = TIRE REAR LT235/85R16/E BL R/PE ST TL HWY (9590803) TIRE(YYN) ZN3 ZY1 = COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
that's right out of the gm cataloge sorry for it being all bunched all together wasn't showing that way in preview
Damn that's one hell of a truck! Perfect for an LS swap since that 4l80e already has it's own stand alone controller. Congrats, I'd have bought it in a heartbeat!
