Vin #'s looked at please
JohnDeere
Houston, Texas
Ok I bought a 454 and th400 tranny friday. It was said to come out of a 80's tow truck. Can I get someone to look up the vin #'s I pulled off the engine heads and tranny and tell me what exactly they are. thanks
Engine block.....GMT12........14015445 P........E19-81.......T0609TRL(above timing chain)
Heads.....GM4T....346236....E28-82......GM1t....346236....e6-81
Tranny....40x.....(it had a tag on it, all I could read was just TURBO 4##).....(he said it had a 208 behind it, did th400 come with a 208 behind them and if it was a tow truck, wouldnt it be a 1ton so a 205)
Acording to Mortec.com
14015445...454.......78-90...2 or 4 bolt
346236.....75-87...oval...OPEN...454, 120cc chamber, 225/116cc ports
thats all I can tell ya about all the info you gave
^This is from Mortec.com^
This is from nastyz28.com
T=Tonawanda assembly plant;06= the month the engine was assembled; 09= the day the engine was assembled; TRL= the suffix code
Suffix__ year___ vehicle____ Size___ HP _____Comments
TRL ___1981____ truck_____ 454___ 210_____ LE-8 VIN W, AR, 20, 30
Abbreviations: AB = Air Brakes, AR = Air Injector Reactor, CA = California, HD = Heavy Duty, hdc = heavy duty clutch, HP = High Performance, LP = Liquid Propane Gas, PG = Powerglide, mt = manual trans, mt-3, 3 speed manual, SHP = Special High Performance, TH = Turbo Hydramatic, ti = transistor ignition. Induction is one (1) 4 barrel carburetor unless specified.
I hope this helps,
Mike
Suffix__Year____Vehicle___Size___HP____Trans___Comments
TRL____1973____truck____454____240___400____LS-4 VIN Z, L, AR, 10
TRL____1974____truck____454____245___400____LS-4 VIN Z, L, AR, 10, 20
TRL____1978____truck____454____250__________LF-8 VIN S, fwd
This is more info from NastyZ28.com
Hope this helps,
Mike
I hope this helps,
Mike
thanks for the help.
