YZEATER
the vin tag should be on the dash correct? i think the previous owner put in a different dash pad and it's covering it, because i have another '80 3/4 ton and it's on the dash.
Craig Artzner said:He's just talking about the vin tag only. On the later trucks the vin number should be on a metal strip at the lower front driver's side dashpad, viewable from the outside window...
Craig Artzner said:He's just talking about the vin tag only. On the later trucks the vin number should be on a metal strip at the lower front driver's side dashpad, viewable from the outside windshield...the '79 and later dashpads had a notch cut in them for that reason I think.
I'd suggest removing the inner door panel to get at the latch and stuff from there but I'm sure that was going to be your last resort. Something probably came unhooked in there...YZEATER said:i'll check tonight, need to make sure it matches the title.
any ideas on getting the rear door open. the latch from outside does nothing, the button stays pushed in. the door lock moves up and down. the inside door handle does nothing.
x2.. and my truck from a few yrs ago was a 77 gmc.. no title. i found another truck a 78 chevy pick up, had title i cutted the vin number out and welded it in the 77 and grinded it smooth, it looks factory. but thats illegalCraig Artzner said:I'd suggest removing the inner door panel to get at the latch and stuff from there but I'm sure that was going to your last resort.
