ok I think I have figured out GM's reason for using a cam timing that seems really dumb in a bbc.
From what I've read and how I feel my burb drives there a delay in torque deliver that seems deliberate. I know torque management is part of the reason and have read that gm retarded the cam timing when installing it some 9 deg! Well towing a horse home tonight I was riding passenger and the wife was on the big hill maintaining 55 the rpm in second was around 3300, so the only reason I could imagine them doing this was for those times when fully loaded and maintaining 55mpg and gm not wanting to install a larger camshaft reducing drivability just to keep the torque curve growing at that rpm. Because if they installed it straight up or advanced the torque peak would be falling off which is bad once it has to downshift into second on a hill..
