Vortec 454 vs Mark IV 489
Blazer79
Guatemala, Central America
Hello my fellow CK5ers.
I've been building my Blazer for over 10 years now. All thanks to the wisdom found in this site. So far I have my Blazer almost as I've been dreaming it since I replaced the first bolt.
I currently have a Mark IV 454 which was already tired when I swapped it for the original 350. It still has some good low end torque, but it's burning oil, and uphill, a stock jeep puts it into shame. At least it has no oil leaks (I put new gaskets when I installed it).
I've been slowly gathering all the necessary parts for a 489 stroker build, which has always been my dream. I bought another 454 with a set of 049 heads, I already have a comp cams K-kit (everything included and 210/218 duration), a set of crane roller rocker arms, a complete gasket set. I also have a polished dual plane manifold, an Edlebrock Quadrajet and a holley fuel pump currently running in the Blazer. I bought a AZSM EFI manifold and a set of Rochester 38# injectors, and was planning on setting up a Megasquirt EFI.
All I need is to buy the balanced kit I want from summit (Scat SCA-1-91505BI for $1,317.95) and about $200 on the machine work, and maybe later complete the Megasquirt setup with about $200 worth of EFI stuff. The problem is with the current economy, a toddler and another baby on the way, I've been trying to save for my kit for over a year and still haven't been able to afford it.
I'm being offered a Vortec 454 from a wrecked 1998 suburban with about 30,000 miles. It's complete with computer, harness, a bent pulley, 4L80E tranny (cracked case) and transfer (don't know which one is it) for about $800, maybe I can get him to lower it to $700.
Do you guys think this is a good deal? Should I put the Vortec in? Or are they overrated? Should I wait maybe another 6 months to a year (maybe even more) to complete the stroker? Has anyone performed this kind of swap to a newer EFI engine on an old Blazer? How hard was it?
Desktop Dyno says my stroker should have about 550 ft/lbs of torque and about 350hp. I researched for the Vortec's numbers, but found mixed ones. Most say about 290hp and 430 ft/lbs.
Any suggestions? Ideas? Comments.
Thanks.
Stroker 5mpg, Vortec 15mpg. 430 ft lbs from the Vortec would sure satisfy my need for power.......
Plus, its simple power. The Vortec will be bullet proof with stock injection when you get it installed properly. Megasquirt always sounds cool, but also like a headache to me.
