A local buddy of mine just SAS'd his 96 OBS Suburban. It has a Vortec 454 / 4L80e in it. He also installed a 241/205 doubler at the same time and now he is having issues with it not shifting correctly in double low. The transmission shifts fine in single low with the 2.73:1 ratio of the NP241 planetary reduction, but as soon as you pull in the 1.98:1 ratio of the 205 then it stops shifting correctly.
Is there any way anyone knows of that a guy can make the Vortec PCM handle the double low gearing? I know on the newer Vortec LS stuff you can program the tow/haul mode to handle the double low gearing, but the older Vortec does not have a tow/haul mode switch.
I am kind of thinking he may be best to swap to a manual transmission instead or put a manual valve body into the 4L80e and eliminate the electric shifting entirely. This is what I do with Penny and she is happy in 4 low without any input from the transfer case.
