Pics when you get a chance too.
Oh shiz page 5, Alright guys i got the motor in the sub and it runs like a raped ape. The ONLY problem I ran into was the cam thrust plate. On the old block there was no thrust plate, on the vortec it uses a thrust plate. I took two thrust plates and cut the ears off of both and welded them to make a wider bolt pattern. This can be done. So specs are a 92 350 block and vortec cam, homebrew thrust plate, vortec cam, vortec heads, lifters. pushrods, vortec timing chain, and waa-laa! Thaks for your advice.
