dyeager535 said:Well, again, it comes down to aluminum saving you weight.
If 9:1 on iron heads (fast burn chambers are going to let you run 87 at that compression easily) make as much power as 10:1 AL heads, there is no difference except that you have more compression.
But the AFR's are fast burn too. Just called them up and asked. Dave at AFR said it was from the heart shape design that determins if the head is fast burn or not.
He also suggested 190's over the 180's for a 400 SBC.
But still, all things being equal, wouldn't 10:1 give you more HP/TQ compared to 9:1 if both heads were fast burn?
http://www.chevyhiperformance.com/techarticles/148_0401_imp/index.html
After a few pulls, the AFR cylinder heads with 180cc intake runners made nearly the same amount of torque as the original configuration (Vortecs), but it did so 700 rpm higher in the power curve, adding 49 hp to the best Vortec dyno run. Remember, these gains came from a motor with less compression
Also, how did you get the TPI to fit your Vortec heads?
<sigh>
. Now a '92 era L05 motor out of a Buick roadmaster with TBI had flattops in it, also with roller cam but TBI.
