vortec question please help
YOu do need to have the vortec rocker arms (self aligning), and valve covers too (center bolt). And definitely need that bypass hose on the water pump. Are you using used heads or new?
I used a kit from Scoggin Dickey, that included everything (except that bypass hose)
You should use new head gaskets of course, and I used the silicone RTV for the intake gaskets where the intake and block mate.
the water bypass is a new one on me, i know the vortec heads do not have an EGR port, so if its on an emissions controlled engine you need to get the parts for that. but to my knowledge all you need are the heads, intake, and hardware. could be wrong about the water bypass though.
It goes from the port on top of the water pump, to the port on the front of the intake manifold.
Here is a pic of my bypass hose. On the non-vortec heads they have a internal coolant bypass from the intake to the block. The blocks have them, but the vortec heads do not. So you MUST run a bypass hose. Otherwise you will be ripping your hair out trying to figure out why your temp is high and spiking into the red almost instantly when running normally. I went through a 1 year battle with this because no one knew about that issue. The dealership replaced head gaskets thinking they were installed wrong.
Plus It ruined 3 water pumps, a brand new heater core, and a new radiator because of the excessive pressure built up in the system, and suddenly unloading.
