Is there any reason why I couldn't buy a used stock Vortec Thottle body, intake manifold and EGR port then slap them on a Vortec crate motor?
The only other things I would need to run that setup in my 87 K5 with TBI would be a proper tune and a higher psi fuel pump? I should be able to put my factory exhaust manifolds back on too corect?
Am I missing anything or is it really that easy to get a proper running Vortec swap and avoid the stupid high costs of the GMPP conversion manifold?
There is a guy locally selling Vortec upper and lower intake manifolds and throttle body, distributor, alternator, starter, EGR valve and fan/clutch for pretty cheap. Just not sure if I should pick them up. If they will work out for the Vortec swap that would be awesome.
