Fuel pump crapped out my 91 Jimmy. Currently, everything is still stock but I’m planning to do something in the future. Can I put vortec-era fuel pump and still run the stock TBI pressure regulator without issue? Or do I need a stiffer spring?
Did you go with an adjustable regulator or a psi specific spring? Any recommendations on who to get either from?
From what I’ve seen, checking the pressure at the inlet to the TBI is the way to go, but not sure if there’s enough space back there to plumb a tee in without running braided hoses.
I built my own with a longer screw and a nut or two. Adjusted it with a 7/16” end wrench from the bottom. There is a fitting that takes a 1/8npt gauge that will thread into the pressure side
There are adjustable regulators that bolt up
Conversely you can also block off the regulator and put an external adjustable regulator on the return, with a gauge between the injector and regulator to set your pressure
