Vortec to 700
FoolSizeK5
Grovetown Ga
Any advice for fabing a bracket to the throttle body to control the TV cable for the transmission? have a few ideas but not sure about it.
I took my stock bracket, cut off the bottom and just welded in another piece that bolted up to two back manifold bolts. wasnt too difficult, you just have to look at it, and determine where the bracket went on the stock manifold ( lengthwise, depthwise, and widthwise). from there just weld a piece in that connects the bolts to where your bracket needs to be
Was more qurious about hot to attach the cable to the actual throttle body so it had the same arc as on the carborator. So the cable moved with the Throttle same as before.
Just find a TBI setup or carb and measure hieght of both bracket and TB and then distance apart. shouldnt be too hard
