WA State 72 Jimmy
ChefBear
Walla Walla
1972 GMC Jimmy, Original paint, brand new everything else. GM crate 290hp 350 V-8, 465-205, hydro-clutch, Centerforce clutch and pressure plate. High Angle Driveline custom 1 ton drive-shafts. 4wheel disc brakes, drive line e-brake. 14 bolt and a 10 bolt. Ultra Lite gauges, PRP suspension seats, 5 point harnesses, 6 pt cage with seatbridge. 2 heaters! Painless wiring harness. 6” Tuff-Country suspension lift with ORD shackle flip, 1” ORD body lift. 35x14.5x15 Boggers.
$10,000 open to trades.
interested in a 05 nissan exterra with the offroad package?
You should be able to find a decent 30+ mpg commuter car for around $2000-$2500. You better not do a straight trade for one of those!
I'm silly but not that silly. I'm also still looking for a way to keep the truck...
I bought a kit from SW race cars, with an extra main hoop, and then had a fab shop assemble it and build the seat bridge, harness bars and gussets.
Did I mention
New GM Crate Motor, new alternator, power steering pump, water pump, carb, MSD distributor, Hooker headers, Autometer guages, 4 wheel disc brakes, HAD driveline brake, rollcage, PRP Seats, 5 point harnesses, HAD 1 ton drive shafts, New Gas Tank! 1 ton Booster, new lines, etc etc,
