Ok, so I've been having alot of trouble with our '64 Beetle starting - particularly on the 30* mornings - but this doesn't always seem to be related to cold weather. Sometimes after driving it, it still won't start. The speed that the engine turns over is very slow when the ignition switch does work. Sometimes if the ignition switch won't work, I can cross wires and get the starter to turn over but that doesn't mean it will start.... I can bump start it EVERY time.
The starter and ignition switch are new. The battery is likely very old. We've owned the car a couple years now and the battery was there before we got it. It boils off the water pretty quickly (I have to add water every couple months). I took the car to a battery dealer and they checked it and told me it was fine. I don't understand how battery testing works - I don't see how they can tell how much cold weather will change the battery's ability to work...
Anyway, I decided to trickle-charge the battery over night and see how it starts. It fired up really well the first morning, so I've been doing this a few nights in a row now. It fires up every time, very quickly. This morning it is 26* outside and it fired up like it was 80*.
So: What do you think the problem is? Is it the battery? Or do you suppose I have some sort of draw on my electrical system that is dropping the voltage? How do I determine if it's a draw? If it is, that doesn't explain why I can drive the car, shut it off to run into the grocery store for 2 minutes and come back out and get nothing when I turn the key. I'm inclined to think the battery is pretty shot, but I hate to drop $100 on a new 6V battery if that's not the issue.
Colby, you have much more mechanical skills than I do and that is the first thing I'd replace. After some time, most batteries won't take to trickle charging, etc and just need to be replaced.
