buffblazer
On my 86 k5. I did a D60 swap, then a red neck ram steering box that was tapped for hydro assist and also installed a cooler.
Shop aligned the truck but it pulls to the right. My bigger issue is when driving if you take a turn hard, when you straighten up, the steering wheel is off about a half a turn, then say you do a hard turn the other direction it will center back up, then continue another hard turn to the right and it will be off half a turn that direction.
Any ideas? Ball joints and steering components all are tight and nothing is leaking.
