TX Want 75 or Older
frameofftx
Newbie
Texas
$20k or less to spend
I'll buy from any state
Wish List
Diesel conversion
Big block
Manual transmission
4x4
Lifted
Mechanically refurbished
No rust through
Straight frame
Surface rust ok
Sorted out
Drive home
No projects
Wish List
Diesel conversion
Big block
Manual transmission
4x4
Lifted
No rust through
Straight frame
Surface rust ok
Sorted out
Drive home
No projects
So not sure what you are saying here:
Diesel conversion big block... is that either or?
Do you want a k5, suburban, k10, 20, 30... do you even care?
I have a few options in the works so...
Diesel preferred. If not, a big block. I want to grab some gears, so if it's a 350ci with a manual, I can live with that.
I know, kinda all over the map, but makes sense to me
K10, etc ... no preference. I'm only cruising and not towing or rock crawling. Although, the dual fuel tanks with no cab fuel tank does seem appealing. I'm flexible.
