PavementPounder
Registered Member
Rather new to the platform and have not seen or been in many other trucks of the same generation at all, so I apologize for n00bish questions.
I've been doing some searching and it seems that the threads I'm finding all deal with completely replacing all the gauges with aftermarket units. Well, my Suburban isn't nice enough for that just yet.
What I would like is to add a factory-style tachometer to the existing dash. The vehicle is a 1987 TBI 350/700r4/208. I have a speedo and big, stupid fuel gauge forward of the wheel and temp/oil/volt to the left with one blank gauge port.
- Was a factory cluster configuration with a tach available?
- Is it a matter of moving gauges around, or is it just simpler to swap the an entire cluster assembly?
- What application/model/year should I be targeting which would be the simplest to swap in?
