loafer said:What if you ditched the front axle and transfer case, got a length of heavy wall 3" DOM tube, and made your own "dummy" front axle...similar to the 2wd Jeep Cherokees.
You could retain all the steering gear off the 10-bolt and do a spring under conversion in the process. The absence of the front differential may allow you enough clearance for the oil pan.
You would also loose at least 300-lbs of extra weight by ditching the front axle and t-case.
stus84 said:Run the BIG 572 $14,000 and more HP than you will ever use. I saw one on Ebay yesterday check it out.... I will also have to vote swapping for a 2WD maybe a body swap??
dirtwarrior17 said:that is unless were are talking about the aluminum block beast known as the ZL1....
In fact i changed my vote to a ZL1 454. ONLY 15 grand![]()
beater_k20 said:good luck finding a ZL1 454, since A) ZL1s are very rare, and B) all ZL1s were 427s.![]()
Your talking about a "Ram Jet ZL1" A ZL1 is a 427. Just like there are two LT1 350's.Funny how you say that...
). the BBC only weights 130 lbs more than a SBC, put some aluminum head on it and loose that beer gut.
