Wanted 12 bolt rear axle
WyoJeeper
Laramie, Wyoming
I am looking for a cheap 12 bolt, must be in decent shape. needs to have 3.73 gears at a minimum. And local to Wyoming/Colorado.
Thanks
Rick
I'll have a 10 bolt with 3.73s available by the end of this month.
I'll have front and rear available.
Located around Denver.
Marty---
I have a GM 12 bolt, 3.73 from a 71 GMC. The spring pads are narrower than those 12 bolts from 73 and later, but is easy to modify. It has all new brakes, seals, axels, studs, and cover(stock). It will be available in mid june if you can wait. It is located in Sacramento, but may be able to arrange delivery for no charge.
