Wanted: 1st Gen Door Hinges / Latchs
jfortner
Registered Member
Everett, WA
I am starting to look for a set of door hinges and the latching mechanisim. Need both doors. Looking at making tube doors and need something to start with. Within an hour of Seattle, Everett or Wenachee I will come and pick them up.
Since the doors won't be used a truck set will work if someone has a set of those.
Thanks John
1971 K5 under construction :D
I am hoping to find the entire set at once. If I find a set of latches seperatly I will get back with you.
John
I could put a set together.
Is that all your looking for? Hinges with a door latch?
I just finished a set of tube doors myself with quick release hinges, full doors to tube doors in just a couple minutes.
