NH Wanted Parts for 87
GonicGM
Seacoast New Hampshire
Picked up 87 V3500 dually p/u. Someone put a dump on it. Missing a couple of items and want to acquire bed parts to return to p/u box.
Intermediate TBI fuel feed line, from filter to flex hose, V30/3500 with 350 or 454
454 BBC studded oil pan bolts
454 BBC motor mount heat shields
Upper dipstick Tube 454
454 spark plug heat shields
Hanger, dual tail pipe
Dual tailpipe hanger clamp
10085698 tall TBI 91 intake with brackets & hoses
OEM TBI motor plastic spark plug wire retainers and inserts, single and 4 position 4.3, SBC or 454
Doug Thorley 454 headers with A.I.R.
Spare tire carrier heat shield
Under bed heat shields, frame or bed mounted.
Parts to convert SRW bed to DRW:
Dually bedside fillers (inner to outer skin)
Dually bed harness
Red Dually bed rear fender light & metal wire protectors.
87 GMC Service manual
87 GMC Wiring diagram
Red (maroon) factory floor mats
87-91 maroon Drivers seat-belt retractor
Rear frame rail tips from one ton pickup, 3/4 may work.
Factory split tailpipe, cat and brackets from 87-91 one ton VIN R OR V
Harness, dual tank, upper, 87-91, TBI.
Sierra Classic 3500 fender emblems with studs in tact.
I would make you a deal if you were closer. I have lots of parts but need labor help. I am out in Colorado if you were closer I need to swap things from one wrecked truck to another.
1983 wiring book (my 1989 was a carb) no cats or TBI I have the service book for 89 in pdf but is LARGE file
  • 1983 GM Wiring CK Carb trks.pdf
  • 1981-1987-chevrolet-truck-chassis-and-rear-lighting-diagram.pdf
Some updates.
Plan a vacation to Ouray CO and help me swap cabs and get the white truck set up ALL the left over parts from the swap are yours FEE! The D60 and the rear would pay for your travel and the hauling back. Lots of area to camp free. I have a person who will lift the cabs off for me with a backhoe.
