Wanted: PS Pump w/ Hydroboost
SkysTheLimit
Tampa, FL
I need to source a good working power steering pump for a big block. I need the style that is used on a 88 crew cab with the remote resevoir with the half serp & v belt set up. I also need the resevoir.
Going hydroboost and big block and I don't want to bother with trying to hack the existing pump into a bracket & then into the hydroboost system.
Edit: Just to clarify, I don't need the hydroboost unit, just a pump with fittings for a hydroboost.
Lemme know what ya got.
Thx
I have a hydroboost ps pump, with the remote reservoir. But, I think I pulled it off a diesel, and so it has a different mounting bracket. When I did hydroboost on my K5, I think Iwas able to put the bracket from my non-hydro pump onto the hydro pump. I had to remove the pulley to get to all the bolts. Anyway, you can have it for $30 plus the ride. I'll snap a pic of it tomorrow if you like.
Please do snap a pic. Heres some pics of the type of setup I have. They aren't mine but ones someone posted that is similar and I snagged for reference.
I have one like that if you are interested.
