wanted rust free and dent free 81 or newer 4x4 truck cab
i have an 87k30 silverado rust free and dent free cab and frame it has a good bed but some small dents for $500 in ga. pm for pics
Got one. I think its an '84 but can't remember. Its nothing but the bare, bare cab. Totally gone thru bodywork-wise. Is in primer stage right now. Is also an original 2wd cab so you can install your 4wd shifter floor pan and your original VIN plate to prevent the hassles of reissuing titles.
I'm in central Kansas, not far from you. You pick up the cab for $300. /forums/images/graemlins/thinking.gif
[ QUOTE ]
i really need 4x4 cab wes
Kevin
[/ QUOTE ]
If Wes's cab is a 4 spd cab the only difference is the piece that bolts to the floor (which you have on your old cab. Everything else about the 2wd/4wd is the same (with the exception of 2wd automatic tranny cabs that have a welded in center hump).
There really is a difference . I know i lookeed at two of them . the hump is taller back further in a 4x4 the cover on a 4x4 does not fit tight ona 2 wheel drive cab
Kevin
I've got a cherry 87 4x4 cab ... but it's in CA /forums/images/graemlins/mad.gif
Eric M.
