WANTED: small Low rpm tach
jjlaughner
3/4 ton status
Indiana
OK, I dont need the 8000RPM tachs I can find at the autoparts store. I want one of the older full sweep tach. I got a cheap one from jc whiteny and it only moved about 1/2" from 0-3400RPM. I may get a digital one from JC whitney if no one has one. Please send pics!
Thanks
Jeremiah
I have a stock 5" tach, 0 - 5000.
It does not have a housing since it is intedned to go in place of the large fuel gauge and not intended as an external tach.
The cluster it was in died, but that doesn't affect the tach since they always use their own 3-wire harness.
-- Mike
I really dont want to take out the fuel gauge, but if you have the small fuel gauge and the tach I might think about putting it into blazer #2. Whats your price for the tach?
Thanks, J
Yes, I have a small fuel gauge that I can send with it, but the problem that comes to mind is - WOuld it work if you just removed the clock or whatever you have there and put this in?
I don't know the answer to that.
But yes, I do have the small gas gauge that goes with it.
-- Mike
The tach and fuel gauge showed up today, looks good, great job on the packing too! I thought I just ordered new stuff from Jegs /forums/images/graemlins/thumb.gif
Thanks again! Jeremiah
