NM Wanted, suspension parts.....
k5blazerguy
Ruidoso NM
sorry I thought I posted in “wanted section” not sure how to move it......
I have a couple trucks I acquired and will be tryin to give new life to. Maybe small lifts with zero rates and 1” BLs. Unless I come across some good priced lift springs.
83 K30 (red), needs a bit of everything. I just set the chassis on these axles. They aren’t bolted on. And no interior.
86 K5, no interior other than front seats.
86 K30 (brown).
If anyone has these parts laying around and wanna get rid of before I buy at ORD or if you see something I may need let me know.
im in NM
-1" BL pucks, body bushings
- front lift springs
- 56” springs for rear
-FOUND. spring plates for D44 front.
- spring plates for 14BFF rear.
- bushings
- shackle flip for 1 ton.
- FOUND. shackle flip for 1/2 ton
- zero rates
- front brake calipers for 1/2 ton 10 bolt
- HD shackles
Pretty sure I have the spring plates and I believe calipers and stock 56 rears also. I will check for sure tomorrow.
56 rears are off of a 3/4 ton Sub, price is the same with or without tension overloads. $100.00
Calipers are $15.00 each
Also have spring plates( not shown) $10.00 each
I have DIY4X shackle flip for 1 ton, B52 for 73-80, and their FUSH. Also have their longer shackles, too.
