Looking for the support braces that go from the TH-400 to the motor mount area on an 86 K30 with 6.2D. Also need the brace from the T-case to the trans. If you have the bolts too, that's a bonus.
1-tonmudder said:I have some with the bolts.How long do you need it??
kennyw said:They should all be the same length between the bellhousing dust cover to the motor mounts. The Tcase rod that runs to the bellhousing bolt can vary in length depending on the transmission and tcase combo you have.
kennyw said:It doesn't connect to the transmission. The tcase support rod connects to the two large bolt holes on the output side of the tcase.
1-tonmudder said:I should have it all.I'll check.Do you need the thick alum cover for the 400 also??
1-tonmudder said:The rod I have fits a Th400 with a 208,and I could only find one of the other rods that go to the engine,but I will come up with another one if needed.The bolts are in the bag.$45 shipped.
1-tonmudder said:I'm still trying to round up the one missing rod.
Mastiff said:Still looking. Anyone have these things? If I could just get the T-case one I'd be fairly happy, since the dealer still carries the other.
imiceman44 said:I have the one from the tcase to the tranny.
With the long bolt for it.
I could check for shipping for you, and I want $15 for it.
