goathearder
Hey guys, I have been chasing a "warm" start issue for months and it has me totally stumped. Here is some background on the issue and what I have done:
Issue:
1973 K5 with SBC 350. Starts perfectly (two gas pumps and key turn) when its been sitting for a couple of hours. Starts perfectly (no gas pumps and key turn) when its been shut off for less than 5 minutes. Anywhere between 5 minutes and a couple of hours (warm), its a major pain to start. Basically have to floor the pedal and crank for 10-15 seconds to get it to fire. Once it fires, all is good but I can't understand what is causing this.
Troubleshooting:
First thing I did was change the plugs and wires. After that, I thought it might be the dizzy so I threw an ignitor II in the original points dizzy. After that, I thought the electric choke might be sucking and I wanted a new carb anyway so I got a new carb with manual choke. I have tried starting with every possible combination of choke and throttle position and still nothing. I thought it might not be getting enough air so I threw a K&N filter on. Then I came back to thinking it was the ignition so I swapped to HEI with new plugs (gapped at .045) and new wires. Still nothing! I also thought it might be the compression so I checked that and its around 150psi per cylinder (give or take 10%) so I have no issues there. I also have a high torque mini starter.
Results:
With the new carb and HEI the truck runs way better when its running so I am happy about that but I am still having the "warm" starting issue. I can't fathom why it starts easy when cold and when hot but has issues when "warm".
Any ideas???
Issue:
Troubleshooting:
Results:
Any ideas???
