warn 8274 what oil to use
highrider_44s
southern B.C.
what kind of oil do you put in the gear case? /forums/images/graemlins/dunno.gif
this is the winch that has the gear box on the side and the motor sits above the spool with the control box mounted to the motor
if i was guessing i would say gear oil
maby 80/90w
would that be wrong
Re: older style warn winch quesion?
i am sure you are talking about the Warn-8274. Check around on their website and see if they have any info there for you. /forums/images/graemlins/thumb.gif
yea thats the winch
i looked aroud but couldn't find nothing
i'll keep looking though
[ QUOTE ]
yea thats the winch
[/ QUOTE ]
Part Numbers: PN 38631 (12V DC), PN 386312 (12V DC, CE) PN 375832 (24V DC, CE)
Rated Line Pull: 8000 lbs. (3630 kgs.) single-line
Motor: 12V 4.6 hp/3.43kw, 24V 2.5 hp/3.43kw, Series WoundTM
Remote Control: Remote switch, 12' (3.7m) lead
Geartrain: Spur Gear
Gear Ratio: 134:1
Lubrication: 6 oz. SAE 30 (non-detergent)
Clutch (freespooling): Sliding Motor Pinion Gear
thanx /forums/images/graemlins/thumb.gif
i just found that last night
i was looking in the rong spot /forums/images/graemlins/doah.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
