Warn Hub Question?
LIVEAnimals
Wheatland, CA
I just picked up a set of Warns Premium Manual Hubs. My newbie question of the day is, does anything need to be done to the T-Case when these are installed or do they just get installed and enjoy? I didnt think there was anything to do to the NP241 but a friend at work told me otherwise.
I have been taught to never use wheelbearing grease to lube them, use engine oil or something thinner, or it can cause them to be a PITA later down the road. Could be wrong, but its never went bad for me doing it that way.
I usually use ATF. The reason is it gets cold up here and when that grease is as thick as it is at 30 below, it's almost impossible to turn.
