Warn hub Questoin
86haubs
Lemoore, CA
Okay I am pretty unfamiliar with the 4wd drive train and mechanics, but I have a rattle coming from my from axle, it sounds like the hubs. Is this an easy fix or do I have to buy new hubs? They are the higher end Warn hubs, don['t remember the model number. The guy I bought the truck from said they are fairly new, if I had to guess the age I would say 3-5 years old.
if there is a problem with the hub, it shouldn't be tooo hard to bust out the allen-wrench, take off the little outter-cover part and look at it to see. If there are any stripped splines or un-identifyable bits of metal inside there, then you have a problem. If there ain't, the hub is prolly fine and its something else.
j
