Ok we'll since I got a whole bunch of Pm's after posting a pic of it... I'll just make a thread.
I can't take any credit. It was built by pricygmc's dad about 20 years ago. Little hard to explain but here goes.
It's basically a barrel inside of a 55 gallon drum. I believe the inner part is from an old water heater or old oil furnace.
The oil is run through a piece of stainless tubing through both and into the middle barrel with a cast iron pan in the bottom.
There is a lip welded on the inside of the big barrel a foot up, and a lip on the outside of the small barrel same height, the small one seals to the other one with some of that high temp rope stuff.
Holes are drilled into the sides of the bottom portion of the small barrel to let air in from those two small fans on the sides.
The squirrel cage then blows against the upper portion of the inner barrel that gets hot and that's where the hot air comes from. And the fumes and smoke go out the exhaust pipe and out the ceiling.
That top piece on the small barrel just sits there.
An electro motor turns the oil pump and that and the blowers are on separate switches.
The red box on the wall is the oil container.
Turn the oil on, let the pan fill a little and toss a rag in and it lights.
Thing cranks some heat. I was in a t shirt and still sweating.
Lemme know if I missed anything and ill get more pics.
