it's still my prob? JR sat for a month with and empty tank when the weather started to cool off at night. it ran great before i let it sit.
when i went to drive it ,i could barly do 15 mph.i put in 6 or so gallons thinking condensation but it still ran crappy. so i crippled it home threw in half a pint (all i had) of dry gas and then added about 8 gallons more.the next day i drove it and could get to 40 mph and then still bogging unless i let off the pedal and hit it again real fast then it would lurch and bog again.so like a dope i added more gas let it sit ,next day the same thing.so out comes the starting fluid to check for vacume leaks. there are none,the the fuel filter still idles rough and can't even spin the tire. and it idles low. if i mist the carb with starting fluid it perks up and if i pour a little gas in the carb while its running it idles up and smoothes out.soooo what do you think ****ty gas????thanks
if that has lasted the last 18 years i'm impressed.seriosly there is nothing but rubber and steel line there.from the tank to the fuel pump. maybe 104 octane boost to help it run better till i run the **** out??
even if you leave it at your parents house.my dad has at least 10 trucks that belong to someone in his yard.
the truck never holds a prime of gas, could that be because of the pump or the carb dumping?if it ran that morning it starts that evening with the turn of the key but the next day i either have to let it crank for over a minute or pump it.
thanks daryl
