Kain
3/4 ton status
Had trouble getting the old distributor to work so i replaced it after doing intake gaskets
topped off fluids changed oil and it ran strong but i took plugs out to read em and number 1 has water
around the electrode. Unless the intake gaskets i just put in didnt seal i have a head gasket that failed.
Is there a way to test it to see? i have a compression leak down tester coming. also hear of test strips?
what are they and where o you get em?
