badmix
I yanked my carpet out years ago due to musty smell that was always there. I put down rubber flooring with insulation under it and still had that smell. Well, when I yanked the flooring up to get interior Line Xd the insualtion was wet. So, I know water is getting in somewhere. Well, today I went to car wash to hose off truck from sitting under trees for weeks and seen water coming in on the passenger side. Its coming out from the heater box. I went to a shop and he said that my drain hole/vent is probably clogged with leaves and dirt. I looked (1/2 azzed) and didnt see any drain hole. I know the A/C needs to drop condensation somewhere. Usually there is a short rubber hose that comes out from the firewall and points down.
ANyways. what areas or things should I check? I dont really want to tear anything apart that I dont need to. First thing I was going to do was find the drain hole and then I was going to take the one side of the evap box off, that seems to be the easiest places to start.
ANy suggestions, comments, opinons????????????
, the kind that goes in the ashtray of the truck. weird, anyways. After I had everything off. I dilegently poured water BELOW the windsheild gasket, as to rule out the windsheild all together. Sure enuff its getting thru at the passenger side vent thingy , by the kick panel. I took it apart and did the water test, water poured onto the floor boards this time. So, Im guessing the seal is fubar. Its entacted, just very flat. So, where can I get a replacement for this. ANythings to get a generic one that I could double up, or would that not be necessary??????????? Does anyone know if GMpartsdirect would have this seal and if so, do you have the part number. Im getting ready to place an order with them soon anyhow.
