Water pump change on 05 Dodge 5.9?
big pappa b
3/4 ton status
Toney, AL
Pump looks simple enough. Any pain in the ass I should be aware of? Knew it would happen soon since I was at 124k
Take the whole air cleaner box out. They take forever to bleed all the coolant out. Otherwise its 2 bolts and a belt
I hate a f'n serpentine belt tensioner^%&*^*%$##^$#^% :doah:
Got the belt off using a pry bar on the tensioner. Still had to wiggle the belt off,. Got the old pump out and new one on. Can't get the belt back on. I need a nd set of hands or something. Using the pry bar I'm still quite a ways from getting the belt back ob the pulley. Is any one set of pulleys easier to get the belt back on than another??
should be able to use a 1/2 drive breaker bar on the tensioner, might make it easier.
might be 3/8ths
Haha..I when you mentioned 1/2" breaker bar I went looking for a place to put it..duh..easy peasy. Bad new is it decided to leak a little so I pulled it off and found the new seal had a big crimp on both sides. Put the old one in. doubled up on the gasket sealer and will let it sit overnight. I'll brave the snow and cold tomorrow, refill it and check for leaks again.
